Hello Guest it is November 13, 2026, 09:47:05 AM
Author Topic: Softlimits  (Read 188744 times)
Re: Softlimits
« Reply #80 on: October 31, 2006, 02:38:19 PM »
Art
 sorry to be a pain but just tried the Z offset that Chris (Creap_Pea) was mentioning a few pages back and it still gives a Z softlimits warning., ie set G54 offset to Z-200 have Tool Z offset to +200.
« Last Edit: October 31, 2006, 02:41:40 PM by Hood »
Re: Softlimits
« Reply #81 on: November 01, 2006, 01:56:11 PM »
Thanks a lot Art/Hood, I can see you have both been busy.
Good to see X and Y softlimits warnings seem to be working properly, Just need to sort the Z out then it will be perfect.
Chris
Re: Softlimits
« Reply #82 on: November 06, 2006, 10:15:18 AM »
Just tried version R2.0.008, still no joy with the tool offsets.
I guess you probably haven't had the time to work on it or it's proving to be harder to sort than first expected, anyway keep up the good work.
Chris
Re: Softlimits
« Reply #83 on: November 10, 2006, 02:18:51 PM »
Any luck with this yet.
Didn't notice any difference in version R2.0.009
Chris
Re: Softlimits
« Reply #84 on: November 10, 2006, 05:23:13 PM »
I think that Art needs a bit more data to show right where the problem is... IT is very hard to get stuff like this fixed when you are sitting at your desk and it is not doing it :(
www.newfangledsolutions.com
www.machsupport.com
Re: Softlimits
« Reply #85 on: November 10, 2006, 06:24:22 PM »
Hi
This is as simple as I can get it, set Z work offset to say -200 and the tool offset to say 200. Softlimit on -Z must from -10 to -199. This will give a warning but then if you run the code it won't go onto the softlimits.
G90
G43H1Z-1.
G1Z-10.F1000.
G0Z-1.
M30
Then try the same program with a Z workoffset of 0.0 and 0.0 in your +Z softlimit setting.
It will rapid straight on to the softlimits with no warning.
Hope this helps
Chris
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: Softlimits
« Reply #86 on: November 11, 2006, 09:09:20 AM »
Chris:
  up, sure enough, I was subtractin the G49's instead of adding.. fixed for next release. That may be it for the softlimits. :)
Art
Re: Softlimits
« Reply #87 on: November 12, 2006, 06:54:09 AM »
Art
Spot on, I'm look forward to it.
Chris
Re: Softlimits
« Reply #88 on: November 20, 2006, 05:51:26 AM »
Art
Just tried Version R2.0.011, it works a treat  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
I did find one little bug but it doesn't bother me but may be worth sorting, if you change a tool offset you have to regen the toolpath before starting other wise it just uses the old data for the softlimit warning, so it could possibly run onto the softlimits, interestingly this doesn't happen when you change a work offset.
Thanks, I'm a happy man now.
Chris
Re: Softlimits
« Reply #89 on: November 20, 2006, 09:52:10 AM »
Art
I'm don't like saying this but I spoke to soon, I'm having trouble with G2 & G3.
This code gives me a Z- soft warning, with g54 Z set at -70, H3 set at 60 and my -Z Softlimit at -127.0 all in mm.
G21
G17G80G90
T3M6
G0G90G54X0.Y0.
G43H3Z10.
G1Z0.F222.8
G2X5.Y5R5. (something to do with this line)
M30
Sorry, I hope it will be a easy fix
Chris
