Hello Guest it is November 13, 2026, 01:00:52 PM
Author Topic: Softlimits  (Read 188834 times)
Re: Softlimits
« Reply #10 on: July 30, 2006, 03:22:38 PM »
I think we should add in code to look and see if the machine can run the program :) We Know if it is not going to fit..
That would take care of the thud  ;D
Thanks Brian, just out of interest how do "we know if it is not going to fit.."
Chris
Re: Softlimits
« Reply #11 on: July 30, 2006, 08:43:47 PM »
Mach 3 knows the Max and Mins of your program in machine cords and can tell if it is going to run past the softlimits :) SO You will just get an error telling you that it will not fit... Is that any help?
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: Softlimits
« Reply #12 on: July 31, 2006, 03:46:19 AM »
Yeah that would be brilliant, might save some thuds ;D
Re: Softlimits
« Reply #13 on: July 31, 2006, 07:17:32 AM »
IT should be in the next release
www.machsupport.com
Re: Softlimits
« Reply #14 on: July 31, 2006, 07:34:16 AM »
Thanks, I'm looking forward to it.
Chris
Offline Leeway
  •  149 149
    • LeeWay Workshop, LLC
Re: Softlimits
« Reply #15 on: July 31, 2006, 09:10:05 AM »
Can't you tell now by running a simulation? I think I have tried it before and the simulation said the soft limits would trip or something to that effect. "Simulate Program Run" on the Toolpath screen.
Lee
Re: Softlimits
« Reply #16 on: July 31, 2006, 09:49:33 AM »
I just want to make it automagic ;)
www.machsupport.com
Re: Softlimits
« Reply #17 on: August 31, 2006, 12:44:57 PM »
Brian
Don't want to hasle you but did you ever manage to make it automagic
Chris
Re: Softlimits
« Reply #18 on: August 31, 2006, 08:36:20 PM »
Yes it is in the latest dev version of mach3 :) If it is going to go past the softlimits it will give you a message when you press the cycle start.. or it should ;)
www.machsupport.com
Re: Softlimits
« Reply #19 on: September 03, 2006, 05:14:59 PM »
Thanks Brian I best download the latest version and give it a try.
Chris
