Hello Guest it is August 14, 2026, 05:28:35 PM
Author Topic: Tool measure macro  (Read 107747 times)
Re: Tool measure macro
« Reply #50 on: January 25, 2007, 12:16:28 PM »
Hello Brian,
I will like to ask if You got a chance to look at the XML that I send?
Thank You Marco.
« Reply #51 on: January 25, 2007, 12:54:43 PM »
Hello Marco
Could you please resend the XML and tell me what the problem is?
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #52 on: February 19, 2007, 01:06:26 PM »
Hello to Brian,
I send the XML a while ago and was wandering if You had a chance to look it up?
Also I try to run a tool  measure macro and got the one from Faby (hope is not mad) and put it in the macros,Mach3 profile, but when I try to run it with a cut file Mach just stops for a couple of seconds and goes to cut the next process.it does not  do the tool change. I check the set up in Mach and looks good,the  auto tool  button is check. Any ideas?
Thank You,Marco.
« Reply #53 on: February 23, 2007, 09:18:54 AM »
I didn't get it :( Could you please post it here on the forum?
Brian
www.machsupport.com
« Reply #54 on: February 23, 2007, 09:48:18 PM »
Hello Brian,
Here is the XML,
Thank You,Marco.
« Reply #55 on: February 24, 2007, 04:59:11 PM »
I tested your XML and it is working good here... Could you please post the toochange macro that you are trying to run? Also please update to the latest Rev of mach3 :)
Brian
www.machsupport.com
« Reply #56 on: February 24, 2007, 08:20:57 PM »
Hello Brian,
Well i just got to update to the last version of Mach and the tool macro is posted in the first page of the topic Tool Measure Macro started by Faby.it's the last version of that macro.Thank You Marco.
« Reply #57 on: March 04, 2007, 05:19:09 AM »
Fabiano,
Did you succeed to make macro working OK? I mean accuracy? If yes, could you, please, pot it here. I would like to try it.
Thank you,
Zoltan
Offline faby
  •  74 74
« Reply #58 on: March 05, 2007, 06:45:28 AM »
I have to try some changes and then I let you know if it works...
I have no time at all... so I never work on it.
Fabiano
Offline Scott
  •  140 140
« Reply #59 on: March 06, 2007, 06:35:01 PM »
On the measured value error, if you come at the switch at the same feedrate each time, wouldn't it be consistent enough that if you included a 'Switch Error' DRO or hard code that error in the macro so that it could then be subtracted from the new position.
I use a Z zero touch off plate that measures 0.3125" but I have to fool Mach with a value of 0.3040" and it's always on the mark.
Do these switches have a +/- tolerance that may cause the problem?
Just a thought, I've never dealt with one before.
Scott
