Hello Guest it is November 16, 2026, 09:15:37 AM
Author Topic: Tool measure macro  (Read 112038 times)
Re: Tool measure macro
« Reply #10 on: August 02, 2006, 08:09:19 PM »
Here you are:
http://www.machsupport.com/MachCustomizeWiki/index.php?title=OEM_DROs
This is the Wiki and I would love to see you put your probe macro into the Wiki :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: August 17, 2006, 08:20:00 AM »
Hello Fabiano,
I sent you a PM but I don't know if you saw it. Could you please post a copy of your tool change macro ? It would definitely help me a lot as I have absolutely no experience in VB script.
Jean-Louis
Jean-Louis
« Reply #12 on: August 17, 2006, 07:05:47 PM »
Could you please post more about what you would like?
Thank you
Brian
www.machsupport.com
« Reply #13 on: August 17, 2006, 07:52:48 PM »
Hi Brian,
Sorry I may have used wrong terms. What I actually would like to get is a tool probe macro as described by Fabiano (tool change position --> tool measurement --> tool change position --> new tool measurement).
I'm trying to understand the macro's listed above nevertheless, as I'm a real dummy in scripting, I wanted to get the final macro that Fabiano successfully used as a valid basis to make test on my machine.
Jean-Louis
Jean-Louis
« Reply #14 on: August 17, 2006, 08:37:19 PM »
I hope he will be nice and post the Code :)
www.machsupport.com
« Reply #15 on: August 18, 2006, 05:01:25 AM »
Yes, I hope too ;)
Jean-Louis
Offline faby
  •  74 74
« Reply #16 on: August 20, 2006, 05:28:03 AM »
Here I am...
I was on holiday, I read the new posts only now.
I'll send the code as soon as possible, I keep it on another Pc.
Faby
Offline faby
  •  74 74
« Reply #17 on: August 21, 2006, 08:57:10 AM »
Here it is, my macro:
ChX = GetUserDRO( 1200 )
ChY = GetUserDRO( 1201 )
ChZ = GetUserDRO( 1202 )
Code "G53 G00 Z-1" 'Move the tool all the way up
While IsMoving()
Wend
ZOld = Getdro(2)
Code "G53 G00 X" & ChX & "Y" & ChY 'Move to the probe position
While IsMoving()
Wend
Code "G31 Z-230 F450" 'Z move down untill hit
While IsMoving()
Wend
HitOld = GetVar(2002) 'Get the Position that the Porbe hit at
Code "G53 G00 Z-1"'Z move all way up
Code "G53 G00 X65 Y-200" 'Move to change tool position
While IsMoving()
Wend
MsgBox ("Insert the new tool")
While IsMoving()
Wend
While IsMoving()
Wend
HitNew = GetVar(2002) 'Get the Position that the Porbe hit at
Diff = HitOld - HitNew
DiffABS =Abs(Diff)
If DiffABS=0 Then End
ZNew=0
If HitOld < HitNew Then ZNew = ZOld - DiffABS :A=1
If HitOld > HitNew Then ZNew = ZOld + DiffABS :A=2
Code "G53 G00 Z-1"
While IsMoving()
Wend
Call setdro(2,ZNew)
'FxModel Creation
End
You have to set in mach3 the position of the tool switch
It's not perfect yet, when I change the tool it remain out of 0.5/1mm but i think it's a switch problem.
I'll try to get 3-4 measure value, for the same tool and then keep the average value.
I'll be in vacation for another week so if I won't answer you know why  ;D
Bye Faby
FxModel Team
« Reply #18 on: August 21, 2006, 10:15:27 AM »
Thank you for posting it  :D
www.machsupport.com
« Reply #19 on: August 21, 2006, 10:25:09 AM »
Thanks Faby and enjoy your holidays  ;D
Jean-Louis
