Hello Guest it is October 21, 2026, 03:49:39 AM
Author Topic: Z Axis help  (Read 42131 times)
Re: Z Axis help
« Reply #20 on: March 06, 2009, 03:07:24 PM »
I checked the VB code in screen designer and it's right.
I used Screen4 and I dont think you can see the script.....just that it is a VB button.
You can read the script in the running screen under OPERATOR/EDIT BTN SCRIPT.
It works fine here.
RC
Re: Z Axis help
« Reply #21 on: March 06, 2009, 03:29:33 PM »
I use screen 4 to change it to a VB button. I go into Mach and then operator and edit button script and cannot get an editing page for the ref z. I have the display mode button flashing, the load material, up and down MP1000 control, the send to MP1000 button and the xfr button all blinking. But I cannot edit the ref z button.
And I can see the VB script for the ref z button in screen designer in  MACH3screen.exe. That tells me the script is correct.
Re: Z Axis help
« Reply #22 on: March 06, 2009, 03:40:46 PM »
Just use Screen4 only.
Open your screen in Screen4.
Make the REF button a VB button.
Save and close Screen4.
Then start Mach Plasma (your profile with the same screen)
Operator/Edit Button Script.
Then.........Click on your new pulsing VB button.
Fill in the instructions and save.
Should work.
RC
Re: Z Axis help
« Reply #23 on: March 06, 2009, 04:03:59 PM »
Can you attach your xml and I will see if there is any reason it doesnt work by using it.
Re: Z Axis help
« Reply #24 on: March 09, 2009, 07:04:14 AM »
Here is my xml.
Re: Z Axis help
« Reply #25 on: March 09, 2009, 11:44:05 AM »
I finally got it working. I had to reload the screen set with view in MACH for it to work. Even though the profile was loading when MACH started, the changes i made to it did not take effect until I reloaded in the view of MACH.
it's always the simplest things it seems like.
Thank you for your help and not yelling at me.
Re: Z Axis help
« Reply #26 on: March 09, 2009, 04:58:26 PM »
Great you have it working, downloaded your xml earlier but just not had time due to workload but now I dont have to :)
