Hello Guest it is November 11, 2026, 04:30:42 AM
Author Topic: mpg on ss's lpt2  (Read 13684 times)
mpg on ss's lpt2
« on: February 24, 2009, 11:18:29 AM »
I can't get mach3 (latest version) to see an mpg
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=40&products_id=160
on ss's LPT2 port. I don't see ss's LPT2 port listed in my device manager. Is this the problem? I've used the given xml for using this mpg on the lpt2 port but I think going from ss is a problem. SS's LPT2 port is powered by SS's power, right?
By the way, everything works fine, jogging, encoder, speed, etc. without the mpg.
« Last Edit: February 24, 2009, 11:20:47 AM by kdoney »
Re: mpg on ss's lpt2
« Reply #1 on: February 24, 2009, 02:46:56 PM »
Is the MPG set up in Ports and Pins , Encoder/MPGs page?
« Reply #2 on: February 24, 2009, 03:38:51 PM »
Yes, I used the template xml from the mpg manufacturer. I asked them if these are the settings to use with SS and they guessed it was right.
« Reply #3 on: February 24, 2009, 05:27:30 PM »
They should be the same for either parallel port or SmoothStepper, one thing you may want to check is that in the SmoothStepper config you have pins 2-9 as Inputs checked for Port2
