Hello Guest it is November 23, 2026, 10:03:41 AM
Author Topic: newbie confused  (Read 40506 times)
newbie confused
« on: February 23, 2009, 02:16:40 PM »
Hi
This is my first post, I have been evaluating Mach3 for several months now and have completed my 3 axis table. I thought that I had things worked out but some rather strange things are happining.
I am at this point trying to cut .050 deep and using a small g code of less than 250 lines to make sure that everything is OK.
Problem is that when cutting I get nothing but garbage.... seems that mach has a mind of its own wandering around the Axis, when running code in off line mode (air cutting or simulation) everything seems OK.
Does Mach3  not let you run code with the evaluation software??
Sorry for the dumb Question
Richard
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: newbie confused
« Reply #1 on: February 23, 2009, 02:27:14 PM »
Simulation and real time cutting should be the same.
Post a picture of the screen shot and also your code that way we can work out what your problem is.
It could be just a setting in your config like Inc arcs.
Graham
Re: newbie confused
« Reply #2 on: February 23, 2009, 02:57:17 PM »
how do i get the screen shot????
  •  2,785 2,785
Re: newbie confused
« Reply #3 on: February 23, 2009, 03:00:21 PM »
« Last Edit: February 23, 2009, 03:01:54 PM by Graham Waterworth »
  •  2,785 2,785
Re: newbie confused
« Reply #4 on: February 23, 2009, 03:05:21 PM »
It looks fine to me :-
Re: newbie confused
« Reply #5 on: February 23, 2009, 03:18:54 PM »
is this the screen shot you needed.
  •  2,785 2,785
Re: newbie confused
« Reply #6 on: February 23, 2009, 03:25:29 PM »
OK, so what is your machine doing wrong, the tool path looks fine.
Graham
Re: newbie confused
« Reply #7 on: February 23, 2009, 03:46:54 PM »
seems that mach has a mind of its own wandering around the Axis, when running code instead of cutting the profile of the spade it cuts in diffrent directions actual photo of cut attached.
Re: newbie confused
« Reply #8 on: February 23, 2009, 03:51:26 PM »
Are the distances accurate when you command moves from the MDI?
If you command a G0 move from the MDI does it go to the correct position?
Re: newbie confused
« Reply #9 on: February 23, 2009, 04:05:16 PM »
using mdi and a 1" travel indicator i requested a x.125 then a y.125 and z .050 all came out right
