Hello Guest it is October 20, 2026, 03:09:21 PM
Author Topic: Rapid not working  (Read 16486 times)
Rapid not working
« on: February 22, 2009, 04:12:08 PM »
   If I type in a line of code like:
                              G01 y-.5 F3.
          The move takes several minutes to complete. I am running off line. I know that I am doing or I am not doing something that I should be doing. Can anyone tell me what I need to do to get the feed right?
         ErnieD
Re: Rapid not working
« Reply #1 on: February 22, 2009, 04:15:39 PM »
First off, where are you starting from? if its Y9 then it will take over 3 mins to do that move.
If that is not the problem then what have you got the motor tuning set to?
« Reply #2 on: February 22, 2009, 04:16:33 PM »
I am starting from y.5
« Reply #3 on: February 22, 2009, 04:20:20 PM »
starting from y.5 with a feed of f3 it should take 20 seconds.
What have you got the velocity set to in motor tuning for the Y?
« Reply #4 on: February 22, 2009, 04:23:02 PM »
I am not sure where to check or change the setting.
« Reply #5 on: February 22, 2009, 04:31:29 PM »
Config menu then Motor Tuning.
« Reply #6 on: February 22, 2009, 04:33:30 PM »
in your subject , you have rapid not working. g01 is not a rapid move .
a rapid would be g0.
Ed
Ed VanEss
« Reply #7 on: February 22, 2009, 04:39:08 PM »
Yes, I know. I meant that the move is slow. Sorry about the rapid statement.
