Hello Guest it is November 24, 2026, 06:02:33 AM
Author Topic: Mach Turn Feed Per Revolution  (Read 61522 times)
« on: February 20, 2009, 11:58:52 AM »
Hello,
I just retrofitted a Hardinge HNC Lathe and encoded the spindle with a (Single Index Pulse).  Mach shows actual RPM, so that works good.  I am using simple M3, M4 output to start spindle, but Mach does not control RPM.  IN G95 mode does Mach use actual Spindle Feedback or does it estimates from the Programmed Feed Rate?  Also the Feedrate Display only has 2 digits to the right of the decimal and the Feed Increment only allows a whole number.  This renders override useless in IPR mode when you want a chip load of say .012 per revolution.
To restate the question:
How does Mach use the actual spindle speed for IPR or does it use the programmed feedrate,  and how do I over ride feed rates in IPR in smaller increments?
Bill
Re: Mach Turn Feed Per Revolution
« Reply #1 on: February 20, 2009, 03:50:03 PM »
Mach uses the true feedrate, also make sure you have "Use Spindle Feedback in Sync mode" checked, its on the ports and Pins then Spindle Setup page.
You can change the amount of decimal places by using screen 4, open the screenset, double click on the DRO in question then in the format string put a 3 after the decimal point rather than the 2 it has at the moment.
 Not really sure what you are meaning by
FRO is a %
« Reply #2 on: February 20, 2009, 04:58:08 PM »
Hood thank you for your help.
I downloaded Screen 4 and adjusted the DRO's as I wanted, it appears to increment the feed rate in IPR up or down by the number in the increment box. I wanted .012 and needed to adjust by .001 up or down and it seems to be working that way.
I am still puzzled because when I slow my spindle down manually I do not hear the Feedrate slow down.  If I do not program a spindle speed it will not interpolate even though it sees the actual spindle speed and Mach gives me the message "No Spindle Feedback seen in (G95) Units/Rev Mode ??.   I do have "Spindle Feedback in Sync mode" checked.  What else could be wrong ?
Also is there any way to override the rapid Feedrate G0.
 Bill
« Reply #3 on: February 20, 2009, 05:09:49 PM »
I dont really have a way of testing it on my lathe but should be able to do it on the mill with a bit of trickery, will try and test tomorrow if I remember.
Not sure what you mean by override the RRO, you can have it locked or unlocked  to FRO, is that what you are meaning? Its on General Config page. You can never exceed the Rapid rate set in motor tuning so if you are trying to increase your rapid speed then you need to increase the velocity in motor tuning.
« Reply #4 on: February 20, 2009, 06:15:01 PM »
Hood,
I got my self straightened out on RRO. I am using the Xbox 360 controller and I had the wrong buttons assigned.  Now what I need is the newest version of the Plugin with axis reversal.  But I can not find the Yahoo Thread for it.
I am sure the actual spindle speed is not being used in G95 mode so when you have the time could you look into what you think the problem may be, I mean what I am probably doing wrong.
I appreciate your help.
Thank You
Bill
« Reply #5 on: February 22, 2009, 05:29:07 PM »
Ok, sorry forgot to post back.
The true spindle speed is being used for the feed, to make sure I tested it out on my mill, it doesnt have Mach controlling the spindle speed.
What I did was Type G95 into the MDI to put it in FPR then I typed in M3S2000 so as far as Mach was concerned the spindle should be doing 2000rpm, the spindle requested DRO reflected that. Next I started the spindle and adjusted the speed to 200rpm then did a G1X200F0.5 in the MDI and the axis moved slowly, ie it was doing 0.5mm per rev at the spindle speed of 200 and not the 2000 that was set in Mach.
 What will not happen, if you alter the spindle speed (once a feed has been set) it will not speed or slow the axis, the Feed OverRide is for doing that, the Spindle OverRide will just override the Spindle but leave the feed at 0.5mm/rev of  the initial RPM.
So for example if you originally had spindle at 1000 and fed it at 0.5/rev it would do that, you increase the spindle to 2000rpm and the feed DRO would half to 0.25/rev but the actual feedrate would be constant.
« Reply #6 on: February 22, 2009, 08:26:28 PM »
Bill,
Lee posted a link for the XBOX with axis reversal. Do a search and you should find it. We tested it out and it works great. Additionaly the XBOX works well along with the SmoothStepper now. That will be in the next posted plugin update.
« Reply #7 on: February 23, 2009, 10:47:29 AM »
Hood,
I must have a spindle pulse problem because I duplicated your experiment and found my results remained the same regardless of the spindle speed. I would set G95 S1000 M03 G01 Z-1.667 F.01 this should take aprox. 10 seconds, than I would command it back to
Z 0 again 10 seconds.
I always allowed travel to complete before manually adjusting my spindle speed in half and than doubled aprox. back and forth and never saw a change in velocity measured by time each time I cycled.
I duplicated everything in Mach Mill as well and had the same results.  I am using a Prox Sensor that has a 1Khz switching frequency.
A 3000 RPM spindle would only be 50 PPS.   My DRO reads a smooth RPM only occasional flickering with in 1 RPM.  Spindle calibration show a very flat line even though I am not using the PID Loop I just wanted to monitor it there to see if it was erratic.
Constant velocity or exact stop did not seem to alter the results.  I have the spindle pulse as an Input on Index and nothing on Timing input as I only have one pulse per revolution.  Can you think of any other reason this is not working.
Also thanks for posting the Xbox 360 Controller with Axis reversal.  That is a nice plug in for all of us on a budget.
To the author, Thank You very much.
Sincerely,
Bill
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #8 on: February 23, 2009, 02:19:26 PM »
If you are running in G94 feed mode then no matter what you do to the spindle speed the feed will not change when in G97 spindle mode.
If you run in G95 feed mode and G96 spindle mode then the feed and speed are locked together and the feed rate increases/decreases as the spindle speed rises and falls.
In G97 spindle mode with a feed of 1 unit per minute (G94) and a spindle speed of 1000 the feed rate is 1/1000 = .001/rev if you then drop the spindle speed to 500 rpm then the feed is still 1 unit per minute but the feed rate is .002/rev
G94 is feed per minute e.g. F1.0 = 1"  or 1 mm per minute, axis will move this distance in 1 minute.
G95 is feed per spindle revolution  e.g. F.01 = .010" or .01mm feed per rev
G96 is constant surface speed e.g. S100 = 100 feet or 100 metres/min  spindle speed, speed increases as cut diameter gets smaller.
G97 is fixed speed e.g. S1000 = 1000 revs per minute.
Graham
« Last Edit: February 24, 2009, 04:58:53 PM by Graham Waterworth »
« Reply #9 on: February 24, 2009, 09:57:47 AM »
Graham,
Thank you for the explanation about the distinction between G94 and G95 Feed Rate Modes and G96 and G97 Spindle Modes.
I will be away for a few days but I will try it out as soon as I return.  The G96 and G97 are omitted from the turn manual in the list of G Codes.  But with a search of the PDF I found the explanation in the verbage.  Your explanation is even better than the books.
Thank you all for your support,
Bill
