Hello Guest it is November 22, 2026, 08:10:56 PM
Author Topic: G31 Bug?  (Read 19844 times)
G31 Bug?
« on: February 18, 2009, 09:48:29 PM »
When I do a "G31 Z-0.5000", the Z axis starts moving, and keeps going forever.  Isn't it supposed to stop when it reaches the target position of -0.5000. if it hasn't seen the probe input go active?
  •  9,378 9,378
Re: G31 Bug?
« Reply #1 on: February 19, 2009, 01:59:34 AM »
Thought I would try this and mine does the same - 'no probe, no stop'.
  •  9,378 9,378
Re: G31 Bug?
« Reply #2 on: February 19, 2009, 02:19:44 AM »
Update.
Restarted Mach and it works fine now - stops as it is supposed to. Could it have been something left in a buffer from the previous program ?.
  •  9,378 9,378
Re: G31 Bug?
« Reply #3 on: February 19, 2009, 02:29:11 AM »
Hi Himy,
After trying many possibilities it only happens when 'Machine Coordinates' are checked. So uncheck and problem solved perhaps ?.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: G31 Bug?
« Reply #4 on: February 19, 2009, 03:39:30 AM »
Ray - As far as I can see, G31 works on Program Co-ordinates only - in other words the number you put in the command refers to the program co-ordinate, not the machine co-ordinate, Perhaps you were looking at the Machine Co-ordinates when you did this.
Offline Greolt
  •  956 956
Re: G31 Bug?
« Reply #5 on: February 19, 2009, 05:04:25 AM »
Ray
Is this with the SmoothStepper or LPT ?
Greg
Re: G31 Bug?
« Reply #6 on: February 19, 2009, 09:24:28 AM »
Makes no difference whether I'm in machine or user coordinates.  I zero both, issue the G31, and off it goes, never to stop.  I"m just doing it in simulation, right now, no machine at all.
Re: G31 Bug?
« Reply #7 on: February 19, 2009, 08:58:57 PM »
Turns out, G31 does not work right if you don't have the PP driver installed.....
Offline jimpinder
  •  1,232 1,232
Re: G31 Bug?
« Reply #8 on: February 20, 2009, 02:15:36 AM »
I take it you mean the Mach 3 drivers installed - because it seems to work alright on both my computers, one with and one without machines attached, but both with drivers..
Re: G31 Bug?
« Reply #9 on: February 20, 2009, 10:09:06 AM »
Correct.
