Hello Guest it is October 20, 2026, 03:09:12 PM
Author Topic: Help with Homing/Limits  (Read 13935 times)
« on: February 18, 2009, 01:54:12 PM »
My machine has two motors on my X; the A is slaved to my X.  All works well when jogging and cutting.
Today I decided to setup my limit switches.  I'm using a PDMX-122.  I used pin 11 and ground with Normally opened parallel switches.  All works well so far.
I set X++, X-- and X Home to pin 11 Active Low.  Switches work fine in diag window.
In the MotorHome/Soft Limits section I select Home Negative and Auto Zero to checkmarks.
When I try and to a home, it appears like only one of the motors on the X is actually turning, the other one tries to skip the rack (spring loaded).
Do I have to set another limit for the A-Azis (slaved axis) to work in tandem with the X-axis?  Is there another setting that I am missing?
(jogging and normal cutting work great)
Any help appreciated.
Thanks, Greg
Offline Greolt
  •  956 956
Re: Help with Homing/Limits
« Reply #1 on: February 18, 2009, 02:50:39 PM »
Greg
On the general config page set "Home Slave with Master Axis"
Another Greg
« Reply #2 on: February 18, 2009, 05:13:09 PM »
Ahh,
I knew I was missing something!
I went and put both motors on the same signals from the PMDX122 and that also worked as well (Gecko 203's).  Getting a nice home with de-bounce happening.
Thanks Greg, Greg
