Hello Guest it is November 13, 2026, 01:36:09 PM
Author Topic: Secondary Port for THC  (Read 11462 times)
Offline mrpeja
  •  114 114
    • Embroidery Machines
« on: February 10, 2009, 12:18:03 PM »
I purchased brand new PC (2,3 GHz or something) and new PCI Parallel Port Card. After inserting card into slot, and starting PC BIOS doesn't see the card, and WIN XP also doesn't see it. (I think this is normally). After installing driver for this card, WIN does see it.
The question is: will Mach3 see the port #2 on so installed card?
Mrpeja
Re: Secondary Port for THC
« Reply #1 on: February 10, 2009, 12:43:23 PM »
Yes, if its seen in Device manager then all you need to do is get the address for it from the resouces tab and tell Mach what that address is.
