Hello Guest it is October 21, 2026, 07:01:18 AM
Author Topic: Mach3 and a tube bender  (Read 119190 times)
Re: Mach3 and a tube bender
« Reply #20 on: February 14, 2009, 08:02:35 PM »
Then as far as your encoder is concerened I can no longer help, I have told you all I know to tell you, perhaps someone else can chime in who has more recent experience.
  For DROs, just drop on on the page, and put in the OEM number the UserDRO number or OEMnumber you want.
scott
vmax549
« Reply #21 on: February 15, 2009, 10:08:36 AM »
SCOTT i'll give this a whirl(;-)
OK for now go BACK to the original screen for mach. Set up the encoder for 4 pulses per unit, SAVE the settings . MAKE SURE you are setting the correct pins and ports to the correct encoder input in this case i would use encoder1 which relates to X axis DRO on the settings page.
NOW rotate the encoder 90 degs. WHat does the dro on the settings page report as number of units???
« Last Edit: February 15, 2009, 11:46:35 AM by vmax549 »
« Reply #22 on: February 15, 2009, 12:00:40 PM »
TP,
I am using Encoder 1 X Axis DRO.  I changed it to 4 and saved the units.  After rotating the encoder 90 degrees, the settings page reports 360 degrees.  This value is found under Abs Coords, MPG1, Count.  Should I do anything with the velocity value?  I have tried changing it, but it doesn't seem to do anything.
vmax549
« Reply #23 on: February 15, 2009, 12:17:40 PM »
"""This value is found under Abs Coords, MPG1, Count.  Should I do anything with the velocity value?  I have tried changing it, but it doesn't seem to do anything."""
I have no idea what you are trying to tell me. This has nothing to do with any of that.
YOu should be looking at the ENCODER POSITION  X axis dro ONLY. WHat does it display for a value???
« Reply #24 on: February 15, 2009, 12:21:18 PM »
The encoder position X Axis DRO reads -2.5500.  If I rotate the encoder, the DRO does nothing.  The only thing that updates is the MPG1 Count DRO above the Encoder Position X Axis DRO.
« Last Edit: February 15, 2009, 12:25:49 PM by supahonkey »
vmax549
« Reply #25 on: February 15, 2009, 12:41:37 PM »
(;-) YOU don't have the encoder setup correctly. IT appears you are trying to setup an MPG.
SET up the encoder AS" encoder1" NOT mpg#1. Use 4 as counts per unit.
Then see IF you get a reading on the X pos dro on the settings page.
« Reply #26 on: February 15, 2009, 12:42:22 PM »
Why have you set up the encoder as a MPG? Are you not wanting it as a way of seeing the movement of an axis?
« Reply #27 on: February 15, 2009, 12:49:55 PM »
AH!  I feel like an idiot.  I can't believe that has been the problem this entire time.  For some reason I (1) never saw Encoder 1 under Pins and Ports.  I always thought that Mach 3 wasn't able to handle Encoders, and the encoders had to be read as MPGs.  Nevermind, thanks for the help.
How do I assign a User DRO number to a DRO in screen designer?  The only option I see is OEM number.
« Last Edit: February 15, 2009, 12:58:27 PM by supahonkey »
« Reply #28 on: February 15, 2009, 01:02:46 PM »
Thats probably the way, been so long since I used screendesigner I cant remember, I use screen4 now.
vmax549
« Reply #29 on: February 15, 2009, 03:29:22 PM »
WE have all been there before, sometimes it just takes an extra set of eyes to see the problem.
Screen designer????  HUM , user dros run from 1000-1254 so set the correct number in the oemcode selection.
Click on oemcode and type in the dro # you want.
