Hello
Guest
it is
November 13, 2026, 05:55:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
Pokeys would you use and a driver question
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Pokeys would you use and a driver question (Read 19588 times)
professorburnout
25
on:
February 07, 2009, 08:45:23 PM »
Hello,
I am interested in try the Pokeys interface. How well does this board work is it as good as using the parallel port to control a machine?
Also, when using the Pokeks interface is the Mach driver reguired?
Paul
Logged
Chaoticone
5,624
Precision Chaos
Re: Pokeys would you use and a driver question
Reply #1 on:
February 07, 2009, 09:13:54 PM »
Paul, the pokeys is not a replacement for the motion control sent by the PP or any other device like the Smooth Stepper. It is a add on for additional IO, not motion though. I have one but haven't hooked it up yet. I understand it does preety good at what it was made for.
The Mach driver is required if your running from the PP. If your using the SS (maybe others as well) you will not have to install the Mach driver. This is an added benefit as it reduces the load on your PC.
Logged
If you could see the things I have in my head, you would be laughing too.
professorburnout
25
Reply #2 on:
February 07, 2009, 09:24:50 PM »
Thanks for the quick answer and clearing up its uses for me.
Do you know what other devices can be used for motion control other than the Smooth Stepper?
Paul
Logged
Print
Pages:
1
Go Up
« previous
next »
