Hello Guest it is November 23, 2026, 04:10:19 PM
Author Topic: OEM Buttons Description  (Read 32026 times)
Eduardo
« on: July 21, 2006, 10:37:47 AM »
Please,
Where do i can find full description about all OEM buttons for Mach2 ?
Thanks.
 e-mail: eduardomaka@icom.com.ve
Re: OEM Buttons Description
« Reply #1 on: July 21, 2006, 02:05:35 PM »
There is a list of all the OEM codes for DROs, Buttons etc in the wiki, you will find it here http://www.machsupport.com/MachCustomizeWiki/index.php?title=Main_Page
 This is for Mach3 though so whether it will be the same for Mach2 I dont know.
Eduardo
« Reply #2 on: July 25, 2006, 07:23:40 AM »
Hi, hood
Yes, i have that list, but it doesn´t describe the meaning of the buttons.
Many thanks,
Eduardo
« Last Edit: July 25, 2006, 02:59:27 PM by Eduardo »
Offline Scott
  •  140 140
« Reply #3 on: November 21, 2006, 03:05:41 PM »
Is there a OEM button/led # for "Turn off Spindle" in General Config under Pgm End, M30 or rewind?  I'd like to place a button on screen for this.
Thanks for the quick fix for that too Art!
« Last Edit: November 22, 2006, 05:18:57 PM by Scott »
Scott
Offline Scott
  •  140 140
« Reply #4 on: November 22, 2006, 05:19:49 PM »
^bump^
Scott
« Reply #5 on: November 24, 2006, 12:30:40 PM »
They are the same as the ones in Mach2 on the Wiki that should do it for you :)
www.newfangledsolutions.com
www.machsupport.com
Offline Scott
  •  140 140
« Reply #6 on: November 26, 2006, 12:46:09 AM »
Thanks Brian,
I have those already, but I don't see an OEM Button/Led # to toggle the checkmark for "turn off spindle" in the "Program End, M30, or Rewind" group.
Much like the OEM Button # of 347 isn't listed for CV Distance.  343-347 are listed as "reserved".
I guess I could just place a button on screen and start cycling through the numbers to see which one will check/uncheck that option.
« Last Edit: November 26, 2006, 12:47:48 AM by Scott »
Scott
« Reply #7 on: November 26, 2006, 07:58:05 AM »
I don't know the exact syntax, but use something like:
 code "M5" for the button script
« Reply #8 on: November 26, 2006, 09:25:57 AM »
Yup you can use the ues CODE"M5" and that will turn the spindle off :)
www.machsupport.com
Offline Scott
  •  140 140
« Reply #9 on: November 26, 2006, 11:38:29 AM »
Sorry guys, but that's not it either.  That's OemButton 110 which is already on the screen.  Maybe I need to rephrase my question and explain what I want to do better.
In the "General Config" dialog, in the section for "Program End, M30, or Rewind" there is a check box for "Turn Off Spindle" which will disable turning off the spindle at a program end, M30, or rewind.  I want to have a button and led to toggle that checkmark in the same manner that the CV distance button and led on the settings page toggles the checkmark for CV distance tolerance in the general config dialog.  I don't want to turn the router off, I want to keep it on.
The reason for this is that I'm making a wizard for a certain thing that I do a lot of.  While doing this, I want the spindle (in my case a router) to keep running while I swap out a blank and cycle start after a rewind instead of it turning off and on, off and on,.....
I'm just being lazy, and don't want to open the general config dialog each time I need to change this setting.  I would also like to be able to "Set" it in a macro or wizard.
I hope this explains what I want to do a bit better.
Scott
