Hello Guest it is October 25, 2026, 03:41:10 AM
Author Topic: Motion Controller Info Needed  (Read 16295 times)
« on: January 28, 2009, 11:03:42 PM »
I have been looking at Mach3 and would like to use it on a Hardinge CHNC 1 Lathe I have. I dont like the idea of sending data through the parallel port. Is there anyone out there that makes a USB or better yet a PCI motion card that works with Mach3? Thanks.
Offline smurph
  •  1,575 1,575
Re: Motion Controller Info Needed
« Reply #1 on: January 30, 2009, 05:47:57 PM »
Take a look in the PlugIn Download section.  There, you will find all other controllers that operate with Mach at this time.
Steve
« Reply #2 on: February 03, 2009, 04:25:46 AM »
Dear sir
                   i am sai krishna from hyderabad INDIA i want the Operating system for Mech3 software i.e(PCB Circuit Board drives) which operates machine according commad given by Mech3.
Best Regards
Sai krishna
  •  9,374 9,374
« Reply #3 on: February 06, 2009, 04:32:52 AM »
Hi Sai,
If you are using stepper motors there are a lot of cheap driver boards available from China.
Here is a link to just one supplier:-
http://stores.ebay.co.uk/I-Wanne-Buy-Shop
  •  9,374 9,374
« Reply #4 on: February 06, 2009, 04:36:17 AM »
Hi Bakeng,
Smooth Stepper is a first class USB to parallel port controller for Mach - although you will still need a stepper driver board as well.
« Reply #5 on: February 11, 2009, 06:40:57 AM »
If you are looking for servo control with Mach3, check out the DSPMC controller at www.vitalsystem.com/dspmc
