Hello Guest it is October 23, 2026, 12:04:48 PM
Author Topic: Turning on a 3 axis router the 4th axis being a indexing head or a rtating head  (Read 15130 times)
HI every one
I would like to know if Mach3 will support turning on a 3 axis router,
Using a forth axis as a rotating head
I would mount stock between centers just like on an lathe and then use router to shape stock or flute round columns, or turn a spiral leg or whatever, Just like you were using an ornamental mill will the add-on mill package software support this type of tool path
any one tried this
thanks rusty
Offline olf20
  •  325 325
Hi rusty
I think the answer is yes. I'm getting ready to try the same thing.
I have a long ways to go, as I have to mount my stepper to the
rotary table that I have.
Rather than adding a lot of $$ or equipment I'm just going to start
out by unplugging one of my current axis and use it as a drive for my rotary.
If I have understood all that I have read the 4th axis / A will only do
degrees without a lot of configuration. I'm just going to do a new profile
and that way I can switch back and forth by simply unplugging my motors.
Here is a link to a discussion that has been a big help to me.
http://www.machsupport.com/forum/index.php/topic,5281.0.html
Keep us posted at to your progress.
olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
You just set it as an A axis and then on general config uncheck the Angular for that axis. Depending on your steps per unit then it will rotate to suit. Example if you have a stepper (200 steps) and  a micro step of 10 then set the steps per unit as 2000 in the motor tuning it would do one revolution if you commanded G0A1.
Thanks Hood
I Just discovered this software it looks like it dose the math for
Mach3 users for 4th axis turning ( I don’t know anything at all about it at this time but iwould like to)
Thanks rusty
Check it out at http://www.legacywoodworking.com/
4-Axis CNC Forms
(part no. S4AXISFORMV1)
$99.00
This spreadsheet allows you to quickly enter parameters to generate G-Code for milling spindles that feature router bit based turnings, flutes, reeds, and spirals such as rope and barley twist. The code is then loaded into Mach 3 to control Legacy's Ornamental Mills with the CNC upgrade.
This Spreadsheet will run in Microsoft Excell or OpenOffice. (OpenOffice is a free program that you can download from www.openoffice.org.)
