Hello Guest it is November 23, 2026, 05:09:56 AM
Author Topic: Shuttle Pro problem  (Read 15579 times)
Shuttle Pro problem
« on: January 27, 2009, 03:07:23 PM »
Hate to keep bringing up the ShuttlePro but I think I have tried everything I have read to get it to work but I must be missing something.  I installed the Shuttle software and then the Mach3 plug-in.  Saw I was not supposed to installed Shuttle software, so I uninstalled it.  When I go to Config:config plugins,  the shuttlepro is installed with the green check to the left and the yellow "config" to the right.  I click on the "config" button and see the ShuttlePro picture and associate the axis with the keys.  Went back and exited Mach3 and then loaded Mach3 again.  When I push the keys on the ShuttlePro, I just get a beep and the error message "Unknown word where unary operation could be.....".   I am running Mach R2.63
Would appreciate any help, thanks
Re: Shuttle Pro problem
« Reply #1 on: January 27, 2009, 03:13:38 PM »
Hmmm...... I'm sure someone else will know how to help here but that sounds like something is definitely now corrupt. Have you tried reinstalling the plugin or reinstalling Mach3?
Always save a copy of your Mach3 XML file just in case.
« Reply #2 on: January 27, 2009, 03:43:24 PM »
Is the plug-in supposed to work with R2.63?  That's mighty old....
« Reply #3 on: January 27, 2009, 03:46:07 PM »
That's actually a very valid point, Ray, thanks-
« Reply #4 on: January 27, 2009, 03:50:10 PM »
Thanks Dave.  That did it.
I can't answer the question about working with  R2.63.  I went and downloaded R 3.042 and installed it with a new download of the ShuttlePro plugin and it's working fine now.
Thanks again for the help.
Doug
« Reply #5 on: January 27, 2009, 04:03:52 PM »
Excellent, glad it's working, it makes a great little pendant.  :)
