Hello Guest it is October 25, 2026, 02:17:05 AM
Author Topic: cannot get motors to turn on  (Read 15330 times)
« on: January 23, 2009, 12:42:06 PM »
Hello.
First time startup on this build. I used a hobbycncpro board and all tested perfect for voltage/amp readouts before I wired it into the 3 axis 425 oz steppers. I setup mach3 config and ran a test program to see if the motors would turn on. I can see mach three running but the motors are acting like they have no power to them at all.
I have read everything I could find but all configs look correct. Could someone tell by my xml file if my configs are ok?
Louis
« Last Edit: January 23, 2009, 01:50:51 PM by louisc »
Re: cannot get motors to turn on
« Reply #1 on: January 23, 2009, 01:27:22 PM »
Yes, please attach and I will have a look.
« Reply #2 on: January 23, 2009, 01:51:36 PM »
Hello hood.
I attached it to my first post.
Louis
« Reply #3 on: January 23, 2009, 01:53:22 PM »
oops sorry I need to see the optician I think ;D
« Reply #4 on: January 23, 2009, 02:04:42 PM »
Not familiar with the HobbyCNC drives but from what I see your xml looks fine. Have you run the driver test to see if it is ok? Also check on the Diagnostics screen and see if there is a pulse frequency.
« Reply #5 on: January 24, 2009, 06:11:24 PM »
Hello.
Thanks for the dbl chk. I had went back to see everyones issues and found one had the motors wired wrong.
I fixed that and fired it right up.
Thanks for a great site
