Hello Guest it is October 20, 2026, 03:08:57 PM
Author Topic: Feed Rate Display Problem in Mach 3 when slaving an axis  (Read 13635 times)
« on: July 20, 2006, 09:44:34 AM »
when setting IPM in motor tuning to 1000 IPM axis will run at 1000 IPM but when i slave the Y axis the display shows 1440 ipm and no actual speed increase on that axis.  Am I setting something wrong.  Occurs in lockdown release.  XYYZ machine configuration and the other axis seem to be fine.
Re: Feed Rate Display Problem in Mach 3 when slaving an axis
« Reply #1 on: July 20, 2006, 10:19:26 PM »
the a-axis check box for angular is not checked either.......i don't know if this is just the way it works but seems like a bug to me.  Also I am running the rutex 2020 drives if that make a difference.  :)
« Reply #2 on: July 22, 2006, 05:21:33 AM »
hello
« Reply #3 on: July 22, 2006, 08:43:00 AM »
I was thinking that we fixed that one... I will tell Art about that when he gets back
thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: July 22, 2006, 09:13:16 AM »
ok thank you
