Hello Guest it is November 22, 2026, 10:04:45 AM
Author Topic: Does Mach R3.00 support ASCII or RTU modbus?  (Read 17822 times)
« on: January 20, 2009, 05:57:23 PM »
It's not completely clear if the default for Mach3 if modbus communication is ASCII or RTU.  Anyone know?
Re: Does Mach R3.00 support ASCII or RTU modbus?
« Reply #1 on: January 20, 2009, 06:29:50 PM »
Mach3 only supports RTU. It does not support ASCII.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
« Reply #2 on: January 20, 2009, 07:23:07 PM »
Peter -
Thanks.... that marks one thing off the list of possible problems.
Do you know what the "Report Slave ID" and the "Read Excp Stat" buttons in the Modbus Serial Control Monitor dialog do?
david
« Reply #3 on: January 20, 2009, 07:26:48 PM »
Peter -
Outside of the built in Modbus test application in Mach3, do you have a recommendation for a application for testing Modbus manually?
david
« Reply #4 on: January 20, 2009, 07:43:23 PM »
Peter -
david
Yes ModbusPoll, thats what I use.
http://www.modbustools.com/modbus_poll.asp
Cheers,
Peter.
Homann Designs
