Hello Guest it is October 20, 2026, 07:45:05 PM
Author Topic: Problem with Cut Rectangle  (Read 38515 times)
« on: July 17, 2006, 10:13:02 PM »
I am using version 1.90.065 of Mach 3 and keep getting errors when using the Cut Rectangle wizard.
I am running it twice to get two nested rectangles with the following settings
0.115 diameter tool
HSS
2 cutting tips
x position 0
y position 0
(in center of rectangles)
corner radius of .1
length of inner rectangle = 2"
width of inner rectangle = 0.75"
0 rotation
Conv mill
inner mill side for inner rectangle
pitch 0
rapid height 0.1
depth 0.27
step depth 0.1
for outer rectangle I use the same setting except for
length of rectangle = 2.5"
width of rectangle = 1.25"
outer mill side
When I run the wizard for the inner rectangle everything is fine, but then when I run it for the outer rectangle I get a Mach3Scripts message that says "Error on line 617 - Type Mismatch"  and then it brings up the VB scripts editor.
I suspect that I am probably doing something stupid as I am a total beginner at the Mill and CNC but it still probably should not be dealing with the error in the way it is.
Any suggestions.
David
Re: Problem with Cut Rectangle
« Reply #1 on: July 18, 2006, 10:46:23 PM »
thank you David, I will be looking into it.
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: July 28, 2006, 12:29:55 PM »
Any luck with this Brian?
David
« Reply #3 on: July 29, 2006, 07:11:10 PM »
Fixed for the next rev
www.machsupport.com
« Reply #4 on: July 29, 2006, 07:21:27 PM »
Any idea when that will be?
David
« Reply #5 on: July 29, 2006, 07:22:17 PM »
I will ask Art :)
www.machsupport.com
