Hello Guest it is November 13, 2026, 10:00:30 AM
Author Topic: Need limit switch help  (Read 13232 times)
IQchallenged
« on: July 17, 2006, 06:20:27 PM »
Have my X axis up and running but have no way to keep it from crashing into the frame if I make a mistake on my Gcode. Running 640 motors and Geckos with Mach3. 1. Do I need to order NO or NC? 2. Where to get them? 3. What wire to interrupt? 4. Do I need to change my Mach settings? Any help will be appreciated.
Re: Need limit switch help
« Reply #1 on: July 17, 2006, 06:24:33 PM »
You should get a NC switch and you can get them  from AutomationDirect.com . They have very nice limit switches.
http://web3.automationdirect.com/adc/Shopping/Catalog/Sensors_-z-_Encoders/Double-Insulated_(PBT)_Limit_Switches/Side_Rotary_Lever_with_Polyamide_Roller_Actuator/ABP1H41Z11
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
Yodawill2000
« Reply #2 on: September 28, 2006, 03:28:21 PM »
Brian,
Is that switch tripped from either side ?
As in mount it in the center and a stop on either side of the table will close it?
Thanks in advance.
« Reply #3 on: September 28, 2006, 08:16:48 PM »
Yup :) That is how the the old mill I had worked... you are very good to figure that out!
www.machsupport.com
Yodawill2000
« Reply #4 on: September 28, 2006, 08:27:02 PM »
Sweet.
Only three of em' wont cut into the beer budget too deep  ;D
Thanks bud.
Chips will occur soon !!  <--Remember time is relative and stuff  ;)
