Hello
Guest
it is
November 13, 2026, 11:09:52 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Re: digitize wizard
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Re: digitize wizard (Read 18948 times)
tulip6
6
Re: digitize wizard
on:
January 05, 2009, 12:55:37 PM »
Hello
My name is Pierre
I am newbie on Mach3
I am searching more information about the wizard digitize hen I file my all coordinated but without the X on Y and Z on each line of gcode
thank you for your help
PS. excused my English
Tank you
Overloaded
4,923
Re: digitize wizard
Reply #1 on:
January 05, 2009, 03:45:47 PM »
Hi Pierre,
I have not used the Digitize Wizard but took a look to try to help you out.
Is the picture I posted what you are referring to ?
I'm not quite sure how it is supposed to be but it DOES appear to be missing something.
Maybe someone else can help.
RC
Carnoustie, Scotland
Re: Re: digitize wizard
Reply #2 on:
January 05, 2009, 04:22:36 PM »
I have never used it either but was under the impression it put out a point cloud and you needed to use a programme to convert the point cloud to G Code. Maybe someone that has used it will be able to advise better.
ger21
6,295
Reply #3 on:
January 05, 2009, 04:33:18 PM »
Why do you need the XYZ in there? You can always load it into a spreadsheet and add them in pretty quickly. I wrote an autocad macro to create a mesh in AutoCAD from the point list. It's posted here somewhere.
Reply #4 on:
January 06, 2009, 04:02:10 PM »
Just by chance I stumbled across this, if you go to the Config menu then Ports and Pins then Mill Options you will see a box that if checked may put X Y and Z letters in for you, not tested it but certainly looks like thats what its for.
Overloaded
4,923
Re: digitize wizard
Reply #5 on:
January 06, 2009, 04:27:40 PM »
BINGO !
Thanks Hood,
RC
Reply #6 on:
January 06, 2009, 04:30:26 PM »
Mach never ceases to amaze me
tulip6
6
Reply #7 on:
January 07, 2009, 02:47:42 PM »
fantastic it works very well
thank you all
Print
Pages:
1
Go Up
« previous
next »
