Hello Guest it is November 13, 2026, 10:51:26 AM
Author Topic: Re: digitize wizard  (Read 18941 times)
Re: digitize wizard
« on: January 05, 2009, 12:55:37 PM »
Hello
My name is Pierre
I am newbie on  Mach3
I am searching more information about the wizard digitize hen I file my all coordinated but without the X on Y and Z on each line of gcode
thank you for your help
PS. excused my English
Tank you
Re: digitize wizard
« Reply #1 on: January 05, 2009, 03:45:47 PM »
Hi Pierre,
  I have not used the Digitize Wizard but took a look to try to help you out.
Is the picture I posted what you are referring to ?
I'm not quite sure how it is supposed to be but it DOES appear to be missing something.
Maybe someone else can help.
RC
Re: Re: digitize wizard
« Reply #2 on: January 05, 2009, 04:22:36 PM »
I have never used it either but was under the impression it put out a point cloud and you needed to use a programme to convert the point cloud to G Code. Maybe someone that has used it will be able to advise better.
« Reply #3 on: January 05, 2009, 04:33:18 PM »
Why do you need the XYZ in there? You can always load it into a spreadsheet and add them in pretty quickly. I wrote an autocad macro to create a mesh in AutoCAD from the point list. It's posted here somewhere.
« Reply #4 on: January 06, 2009, 04:02:10 PM »
Just by chance I stumbled across this, if you go to the Config menu then Ports and Pins then Mill Options you will see a box that if checked may put X Y and Z letters in for you, not tested it but certainly looks like thats what its for.
Re: digitize wizard
« Reply #5 on: January 06, 2009, 04:27:40 PM »
BINGO !
Thanks Hood,
RC
« Reply #6 on: January 06, 2009, 04:30:26 PM »
Mach never ceases to amaze me :)
« Reply #7 on: January 07, 2009, 02:47:42 PM »
fantastic it works very well
thank you all
