Hello Guest it is November 13, 2026, 03:02:43 PM
Author Topic: Mach3 R3.042.020  (Read 16316 times)
Mach3 R3.042.020
« on: January 03, 2009, 07:35:12 AM »
I tried the new lockdown version of Mach3,  R3.042.020,  and found that it will not allow a correct Z start for the "Run From Here"
Option. It goes to the correct X and Y and then the Z moves into the positive direction until it reaches the Z+ limit. It seems to ignore the Z data in the program?  Does any one else have this happen? I switched back to Mach 2.********* and ran my parts?
Danny
Re: Mach3 R3.042.020
« Reply #1 on: January 03, 2009, 07:59:08 AM »
Sounds like you may be having issues with the safe Z position. Can you attach your xml and I will have a look.
« Reply #2 on: January 04, 2009, 09:33:45 AM »
Thanks Hood!
I changed the Safe Z to 1 inch and it fixed it!
« Reply #3 on: January 04, 2009, 09:43:03 AM »
Great and thanks for letting me know :)
