Hello Guest it is November 13, 2026, 09:39:39 AM
Author Topic: Mach3 View Screen too BIG for my monitor  (Read 18046 times)
« on: January 01, 2009, 02:44:34 PM »
When I started Mach3 Mill this morning the Mach3 screen was about 30% too large for my 17" monitor.  For some reason it was way oversize.  Haven't had this problem before.
Opened Mach3 Plasma and it filled the monitor screen normally.
How can I correct this?   ???
Hager
Mr. Chips
Retired 3M'r
Re: Mach3 View Screen too BIG for my monitor
« Reply #1 on: January 01, 2009, 03:02:13 PM »
Go to Config menu then General Config and check the Auto  Screen Enlarge option, it will shring your screen to fit your monitor.
« Reply #2 on: January 01, 2009, 03:28:44 PM »
I found the General Config and checkwd the Auto  Screen Enlarge option, however even if I move that screen to the very top I can only see a portion of the OK.  Tried clicking that but it doesn't resize the screen, is there something below the "OK" on the screen that I would need to click on but cannot see?
Mr. Chips
Retired 3M'r
« Reply #3 on: January 01, 2009, 03:30:29 PM »
OK I got it.
Had to shut down Mach and restart then it was OK
Thanks.
Mr. Chips
Retired 3M'r
« Reply #4 on: January 01, 2009, 03:31:40 PM »
you need top restart Mach after you have done the Auto Screen enlarge.
« Reply #5 on: January 01, 2009, 03:32:06 PM »
ah you got it while I was typing :)
« Reply #6 on: January 01, 2009, 03:34:05 PM »
Thanks Hood,  I'm back in the game now.
Hager Hay
Mr. Chips
Retired 3M'r
