Hello Guest it is November 13, 2026, 12:14:56 PM
Author Topic: Gecko 201 Disable?  (Read 12615 times)
Offline Robhi
  •  138 138
Gecko 201 Disable?
« on: January 01, 2009, 12:52:50 PM »
Hi everybody,
happy new year to all of you.
I would like to know the function of disable in Gecko 201, Could I leave it alone and not connect it to any other wire?
What it is the advantage if I connect it (use it) and how could I use it?
thanks you and happy new year again.
Robhi :)
Re: Gecko 201 Disable?
« Reply #1 on: January 01, 2009, 01:21:08 PM »
I know you dont need it as I never had it wired when I had G201's. I have G202's now with the same wiring but on them the disable pin says NC (No Contact I presume)
I would imagine the disable on the G201 would be so you could manually disable them from putting out any step pulses if you wished.
Offline Robhi
  •  138 138
« Reply #2 on: January 01, 2009, 02:56:53 PM »
Hi Hood and all,
Thanks too much for your answer I appreciate that.
Robhi
