Hello Guest it is September 23, 2026, 09:49:48 PM
Author Topic: MachScreen releases  (Read 526112 times)
Re: MachScreen releases
« Reply #120 on: May 16, 2018, 09:39:32 PM »
Also, if you are running Mach3 without the parallel port driver, the LED may not work correctly. Many Mach3 functions rely on the parallel port driver, or a motion controller plugin, to work properly.
Ahhh ok!!
I have an Ethernet Smooth Stepper with a CNC4PC's breakout board, running Mach3 on a thin client with Windows XP.
Any suggestions to solve this?
I bought your screenset about 2 months ago, best investment ever!! So, I'm running an unmodified version of your screenset.
I love your screenset, but I'm trying to adapt to a touch screen panel, because I have an HMI with 1024 x 768 of resolution, and the icons and buttons are very small, especially if the operator uses gloves
« Reply #121 on: May 17, 2018, 05:32:34 AM »
As long as you have the smoothstepper plugin installed, it's OK.
The problem is when running Mach3 in "Simulation Mode", with no parallel port or plugin installed.
« Reply #122 on: January 06, 2019, 04:12:40 AM »
Hello, I wish all a happy and healthy New Year.
I released MachScreen Version 1.70.
Changes:
Function "collect bitmap files" is now copying LED bitmap files also
Sizing did not work if “page 0” was not defined
View of user defined button didn't show 183 as user defined
Main window size can’t be set smaller than 600 * 60 pixels
Klaus
« Last Edit: January 06, 2019, 04:34:18 AM by Klaus1311 »
The brain isn't a soap, it doesn't shrink when used.
  •  9,373 9,373
« Reply #123 on: January 06, 2019, 04:38:44 AM »
Hi Klaus,
Wishing you and yours a Happy New Year also and thank you for all the work you do with MachScreen and other Mach related software products.
« Reply #124 on: August 26, 2019, 06:40:39 AM »
Hello
I released MachScreen version V1.71.
Changes:
Minor bug-fixes in function "Collect bitmap files". Control-element types can now be used as a filter.
A few words to that function.
It scans the screenset for bitmap-files and copies / moves them to another folder. This could be handy, to trim bitmap folders from unused bitmaps, or get a new folder organization. It can be dwnloaded from https://kd-dietz.com
Klaus
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #125 on: August 26, 2019, 08:53:47 AM »
Hi Klaus,
are the copied/moved bitmaps updated in the screenset to reflect the new folder location?
« Reply #126 on: August 26, 2019, 10:25:14 AM »
Hi Graham
if "Guide through settings" is set, this function asks for:
target directory (this directory must reside under Bitmaps),
select the pages,
copy or move
file types
control types
all bitmaps found are copied / moved to the target directory and the pathfilenames in the screenset are set to the new path.
This function can not be undone
Klaus
« Last Edit: August 26, 2019, 10:28:24 AM by Klaus1311 »
« Reply #127 on: August 29, 2021, 05:57:33 AM »
Hello
I released MachScreen version V1.73.
Changes:
 1) New submenu button "Move property dlg into view" under menu Options added. This button will move the property dialog to the left top corner of the main monitor
 2) Button File -> "Open file" or "Save file as" within the editor could crash the program.Fixed
Klaus
Offline rcaffin
  •  1,073 1,073
« Reply #128 on: February 01, 2022, 06:00:42 PM »
Hi Klaus
Your website offers English and German versions, which is nice.
However, to select the English version one must click on a button labeled 'Go to Emglish' [sic]. You might like to correct the spelling some day.
Anyhow, many thanks.
Roger
