Hello
Guest
it is
June 12, 2026, 09:42:56 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
FAQs
Z axis help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Z axis help (Read 13322 times)
mailman
10
Z axis help
on:
October 08, 2008, 07:42:38 AM »
I am new to CNC, what is the best way to zero Z axis on my material, so I don't leave a mark when turning on my router. Do I set the zero on my material, turn my controller off and back off of piece manualy. I do not have homing switches. Thanks
Chaoticone
5,624
Precision Chaos
Re: Z axis help
Reply #1 on:
October 08, 2008, 08:06:10 AM »
Just jog to the point you want 0 to be. You can use a sheet of paper between the cutter and work so you don't leave a mark. jog down slowly as you slide the papre and as soon as the papaer quits slideing, stop jogging. Go to the z button beside the Z DRO on the program run page and click it to 0 your DRO.
If you could see the things I have in my head, you would be laughing too.
mailman
10
Re: Z axis help
Reply #2 on:
October 08, 2008, 01:58:21 PM »
Thanks for the help, Mailman
Carnoustie, Scotland
Re: Z axis help
Reply #3 on:
October 08, 2008, 03:58:53 PM »
another similar way would be to jog down to near the surface then back off a bit whilst trying to slide a feeler gauge or gage block under. When it slides under nicely you can then enter the thickness of it in the Z DRO and now your cutter is set for the top of the work. The reason you dont jog down onto a feeler or gauge block is you will damage your cutter if you feed a bit too far, jogging up and repeatedly trying to slide the feeler or gauge under wont do damage.
Chaoticone
5,624
Precision Chaos
Re: Z axis help
Reply #4 on:
October 08, 2008, 04:03:26 PM »
Good tip Hood.
Print
Pages:
1
Go Up
« previous
next »
