Hello Guest it is June 13, 2026, 08:28:37 AM
Author Topic: Step and repeat  (Read 13867 times)
Step and repeat
« on: June 19, 2006, 12:04:49 AM »
I'm having a hard time trying to step and repeat, the old dozer routers you just type in M25 and
it will repeat next to the 1st finished project. How do I get Mach 3 to do the same? Or do I have
to wait till 1 square is cut and x over1/4 inch and re zero all axis then start my 2nd square? I would
think that Mach 3 would have some kind of m code that would do this for you like the old
PDA dozer router programs. I tried M47 and M99 but all they would do was go back over the same
path instead of moving over 1/4 inch and repeating the program. Can anyone help me out???
Re: Step and repeat
« Reply #1 on: June 19, 2006, 06:09:59 AM »
I would do that with Gcode..
Startup block
G98 O1245 Q3
end block
O1245 (this is a sub)
G92 X0.0 Y0.0
G1 Z-.1
G13 I.5 f30
G0 Z1.0
G00 X2.00
G0 X0.0 Y0.0
m99
You are going to have to do this in a sub routine :( there is no M25 type of a macro.
I think we could make a macro like that in VB if we had to....
Brian
www.newfangledsolutions.com
www.machsupport.com
