Hello
Guest
it is
June 10, 2026, 09:19:29 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Limit Switch Problems
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Limit Switch Problems (Read 48203 times)
inivator
102
Re: Limit Switch Problems
Reply #30 on:
July 02, 2008, 06:24:41 AM »
Thanks Hood. I think that will work better for me.........
Again thanks
Inivator
jd1uth
20
Reply #31 on:
July 02, 2008, 10:14:34 AM »
Hallo I have also a problem whith te swithes when i have the home the good direction then the axis go the wrong way , when i change that de then the functions on the keybord are wrong
Last Edit: July 02, 2008, 10:31:22 AM by jd1uth
Chaoticone
5,624
Precision Chaos
Reply #32 on:
July 02, 2008, 02:49:18 PM »
What type machine are you running? Does the table move or the spindle?
If you could see the things I have in my head, you would be laughing too.
jd1uth
20
Reply #33 on:
July 02, 2008, 03:38:09 PM »
Hello Brett
The machine is a Zoltar
http://www.zoltar-cnc.nl/?p=classic
Chaoticone
5,624
Precision Chaos
Reply #34 on:
July 02, 2008, 05:51:28 PM »
JD, have a look at this thread and the link in it as well. I think they will fix you up.
If they don't we will try our best to.
http://www.machsupport.com/forum/index.php/topic,4327.0.html
Print
Pages:
1
2
3
4
Go Up
« previous
next »
