Hello Guest it is June 11, 2026, 02:39:15 PM
Author Topic: Mach3 et SMC800  (Read 8508 times)
Mach3 et SMC800
« on: May 19, 2007, 04:00:21 PM »
Bonsoir, je n'arrive pas à configurer mach3 pour une commande d'axe smc800
merci de m'aider
Re: Mach3 et SMC800
« Reply #1 on: May 20, 2007, 07:46:37 AM »
Hi Philippe
I do not understand the language but if you mean the SMC800 board from CONRAD, i dont think it will work with Mach3 because it has its own interpreter of step and direction signals and therefore it needs special software.
I myself has the SMC1500 with an extention board on it to make it listen to normal step and direction signals.
Greetings:
Willem
