Hello Guest it is June 11, 2026, 09:22:10 PM
Author Topic: Consistency  (Read 9302 times)
Consistency
« on: March 12, 2012, 09:15:08 PM »
I am trying to calibrate my mach3. It is consistently off. It overtravels about. 030 in positive direction and under travels about. 02 in negative direction.
Sent from my DROIDX using Tapatalk
Re: Consistency
« Reply #1 on: March 13, 2012, 05:52:46 AM »
You first need to get the steps per unit correct. Find the correct setting based on going one direction and distance only, make sure you take out any backlash. Then you can check for backlash by doing two opposite moves for that same distance.
Are you using steppers or servos?
Re: Consistency
« Reply #2 on: March 13, 2012, 07:32:14 AM »
Im using servos. Last night I had it running correct in the settings page. But when I went to mdi screen and typed in a motion it way over travelled
Re: Consistency
« Reply #3 on: March 13, 2012, 11:17:22 AM »
Your questions are being addressed in another thread. Please do not start another one on the subject.
Re: Consistency
« Reply #4 on: March 17, 2012, 10:44:43 AM »
My questions are no longer being addressed.  Maybe I can figure it out. Thanks though
Re: Consistency
« Reply #5 on: March 19, 2012, 05:28:55 AM »
attach your xml and say what drives. motors, encoders, pitch of screw and any reduction you have.
Re: Consistency
« Reply #6 on: March 28, 2012, 05:27:13 AM »
I believe its fixed. The breakout boards were interfering with each other. Causing noise I guess. I bypassed one and now its good.
