Hello Guest it is June 12, 2026, 11:09:26 PM
Author Topic: What should I see in the "Diagnostics Alt-7" window if Mach3 configured properly  (Read 30182 times)
Offline Blu
  •  5 5
Hood,
At the diagnostics window the "Time in Int." idles at ~3.5 without any G Code.  When I enter G Code or use the servo frequency generator the "Time in Int." fluctuates between 3 to 10.
Throughout all commands the pulse frequency flutters just below 25KHz.
Blu
That sounds like the driver is working well. Not sure why you would see such changes when jogging X axis only
