Hello Guest it is June 11, 2026, 12:15:04 AM
Author Topic: New Multiple and Complex thread Turning Wizard!!!  (Read 81559 times)
« on: December 26, 2006, 10:37:37 PM »
Here is the Re-uploaded Wizard, (I Forgot to populate the files  :-[  )
I just built a Lathe Threading Wizard called "Quick Turns", you can do Multiple threads, clearances, directions, hands...etc.
I added that nice little "Free Ware" Thread calculation Wizard that was posted up here so You can have an easy access Thread form calculator chart!! It has a Help file for how to use it, please read the "Read Me 1st".
I hope you like it, tell me what you think,
Scott S.
« Last Edit: December 27, 2006, 08:17:52 AM by poppabear »
Re: New Multiple and Complex thread Turning Wizard!!!
« Reply #1 on: December 26, 2006, 11:04:26 PM »
Hi Scott,
    I just tried that and got a blank screen when I tried to pick your wizard. Also got an error on the pick wizard tab. I attached a screen shot. In the zip file, bitmaps, there where no bitmaps. I may have gotten a bad download. Just thought I would let you know.
Amnz
« Reply #2 on: December 26, 2006, 11:18:46 PM »
You are not alone...
 I guess there are a couple bugs in the uploading process....
Both the bitmaps folder and the "quick threads" folder were empty after unzipping.
« Reply #3 on: December 26, 2006, 11:24:14 PM »
I'm sure he will get the bugs out. I don't even have a lathe but had to look at the wizard. It sounds very nice. ;D
Keep up the good work Scott.
Offline ardor
  •  130 130
« Reply #4 on: December 26, 2006, 11:53:21 PM »
I know where you can get one for cheap!!!
There is no approved dental use for WD40
« Reply #5 on: December 27, 2006, 12:01:44 AM »
LOL. I had a look at it today as well as the 55. Will you deliver for that price? ($10.00) I'm in SC. ;D
« Reply #6 on: December 27, 2006, 08:19:41 AM »
Ok, I fixed it, I had didn't populate the files when I made a file to Zip and upload.......duh.
Go back to my 1st original post, and re-download it from there.
Scott
« Reply #7 on: December 27, 2006, 08:42:47 AM »
Scott,
    Good job. I downloaded a few minutes ago and seems to be fine. I wonder if I could use this wizard as an excuse to buy a lathe? ;D
« Reply #8 on: December 27, 2006, 09:21:11 AM »
   And yes, you could use it as an excuse!! The Wife just NEEDS those threaded, romantic candle sticks at the Hot tub.....hehehe
"I was thinking of you, honey, thats why I got it......"
Scott
« Reply #9 on: December 27, 2006, 10:26:33 AM »
This screen shot doesn't show any labels for the numeric entries.  Although the wizard appears to work and can generate the G-Code.
I put the bit map files in MACH3/Bitmaps/TurnBitmaps.  Am I missing something?
Thanks.
John Dammeyer
