Hello Guest it is June 10, 2026, 01:39:27 AM
Author Topic: Aspire file to Mach3  (Read 47131 times)
« on: November 27, 2011, 10:50:57 AM »
Don't know if this was discussed before.  I searched but could not find the answer.
My problem is that I had Vectric Aspire and Mach3 on my machine running Windows XP.
I could generate my g-code in Aspire and when I save it have the option to send the g-code direct to Mach3...if Mach3 was open and running.
I upgraded the PC and is running Windows 7 now.
I can open Mach3...manually load a file and cut, but when I save from Aspire and tell it to send a copy to Mach3, it returns with some error saying 'FAILED TO ATTACH TO MACH'..... Failed to find running instance of Mach.
At this point Mach is open and running and I can manually load the g-code and do my cutting.
Is this a problem of Windows 7 ? or is there a small trick that I missed to get it to work. Thank's
Re: Aspire file to Mach3
« Reply #1 on: November 27, 2011, 12:46:13 PM »
I believe it's a bug in the Mach3 installer. It can be fixed with a registry hack, but I don't know if that information is posted anywhere.
« Reply #2 on: November 28, 2011, 12:48:23 AM »
Thank's Gerry, but how do we find the FIX ?
Offline Greolt
  •  956 956
« Reply #3 on: November 28, 2011, 02:00:38 AM »
Woody
Send me a PM with your email and I will have something for you
Greg
« Reply #4 on: August 11, 2014, 10:47:39 AM »
Before I start a new topic I'd like to ask here if anyone can give me the Information woody got because I have the exact same problem!
Also win7 and probably a driver problem
Thanks!
« Reply #5 on: August 11, 2014, 01:48:05 PM »
You need to manually add a registry entry I think. Sorry, but I don't know what it is.
PM Greg and he will probably be able to still help you.
« Reply #6 on: August 11, 2014, 02:03:45 PM »
Thanks! I found the entry
It is:
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Mach4.Document]
@="Mach4.Document"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Mach4.Document\CLSID]
@="{CA7992B2-2653-4342-8061-D7D385C07809}"
Offline Greolt
  •  956 956
« Reply #7 on: August 12, 2014, 01:28:27 AM »
Glad you found it.  I no longer have it on hand.
Would have had to search as you have done.
Greolt
« Reply #8 on: August 12, 2014, 07:35:02 AM »
No problem,
Hope someone finds this usefull sometime.
Seems to be a problem for everyone with as Smoothstepper/non-Parallel interface and 64bit
« Reply #9 on: February 21, 2015, 04:01:02 AM »
that was very helpful, I too have just upgraded windows and everything else along with moving to smooth stepper, and this patch worked a tread....
thanks for posting steelwolf....
Too much time on my hands: :)
