Hello Guest it is June 10, 2026, 06:41:39 AM
Author Topic: PRO/E to Gcode  (Read 11156 times)
PRO/E to Gcode
« on: November 21, 2011, 03:22:14 PM »
Does anyone know of a way to take .ncl files that Pro/Engineer Manufacturing creates and convert them to work with Mach3 for a 3 axis router CNC? I am new to CNC machining so I am looking for a simple and easy to understand solution. Thanks
Re: PRO/E to Gcode
« Reply #1 on: November 21, 2011, 04:16:33 PM »
Afraid I dont know anything about Pro Engineer, what does the output code look like?
Re: PRO/E to Gcode
« Reply #2 on: November 21, 2011, 05:13:09 PM »
Attached is the output from PRO/E, but it is not Gcode that my cnc will accept. I would think that with how capable PRO/E is at making NC toolpaths that there must be an easy way to process it to Gcode automatically.
Re: PRO/E to Gcode
« Reply #3 on: November 21, 2011, 05:17:51 PM »
Certainly no use for Mach but you already know that ;D
What exactly is Pro Engineer? Is it a CAM programme?
Re: PRO/E to Gcode
« Reply #4 on: December 23, 2011, 01:30:16 PM »
With Pro/MANUFACTURE you should have a copy of GPOST. You can use the HAAS post in GPOST to create a .tap file that Mach3 can use.
