Hello
Guest
it is
June 11, 2026, 04:01:26 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
problems with spindle run on my CNC
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: problems with spindle run on my CNC (Read 14233 times)
dinko
12
on:
June 11, 2011, 11:51:05 AM »
Greetings !!
I have poblems with Connections/Setup on mach 3 with spindle:
i have 4 ports on LPT conroler that i can on/off my electric things.
RELAY1= P1
RELAY2= P16
Pump= P17
Spindle =P14
Spindle speed =P14* i thing i need to regulte extra electronics...
so i need help to setup my MACH3 to on/off my spindle and where to connect
THANKS!!
p.s. : sorry about my english
Carnoustie, Scotland
Re: problems with spindle run on my CNC
Reply #1 on:
June 11, 2011, 12:05:50 PM »
How are you controlling your spindle speed? What kind of spindle/drive is it?
dinko
12
Reply #2 on:
June 11, 2011, 12:20:25 PM »
I have controled speed witout electronics... i need just off/on.. so i need only when start maching to turn on spindel and when its done spindel off. no need to regulate speed
TNX
Reply #3 on:
June 11, 2011, 12:34:30 PM »
Ok so you only need one output to turn On/Off the spindle via a relay.
dinko
12
Reply #4 on:
June 11, 2011, 01:04:23 PM »
i setup on:
Config>Ports and pins
Output signals:
on output#1 :Chacked | 1 | 14 | active
but doesent work nothing
or if i must work on something other setup ??
Reply #5 on:
June 11, 2011, 01:11:19 PM »
Config, Ports and Pins, Spindle Setup and uncheck "Disable Spindle Relays" and enter 1 for M3. see pic.
dinko
12
Reply #6 on:
June 11, 2011, 01:18:58 PM »
i have this seting like you show and i change settings like i saw on video on mach3
output#1 : cahcek | 1 | 1 | active and still dont work...
Reply #7 on:
June 11, 2011, 01:19:59 PM »
Can you attach your xml please and I will see if I can find a problem.
dinko
12
Reply #8 on:
June 11, 2011, 01:36:33 PM »
I hope it will work
tnx
Reply #9 on:
June 11, 2011, 01:39:34 PM »
Sent you a PM
Print
Pages:
1
2
Go Up
« previous
next »
