Hello
Guest
it is
June 12, 2026, 02:46:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Setting Feed Rate
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Setting Feed Rate (Read 7786 times)
cdis
11
Setting Feed Rate
on:
April 06, 2011, 09:21:24 PM »
My feed rate is set at 1.00. I try to change it to 75.00 but it will reset to 1.00. I have tried to change it both on the "program run" and the "MDI" Hope you can help. SOrry for being such a novice. Neil
ostie01
628
Re: Setting Feed Rate
Reply #1 on:
April 06, 2011, 10:59:58 PM »
Is it possible the velocity is set to one in the motor tuning.
Is it the same for all axes.
Jeff
ger21
6,295
Reply #2 on:
April 07, 2011, 06:27:05 AM »
There's probably an F1 in your g-code.
cdis
11
Reply #3 on:
April 07, 2011, 07:34:05 PM »
I will check that
Thank you
Print
Pages:
1
Go Up
« previous
next »
