May 27, 2012, 06:04:40 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  How do I repeat the cut of the same part?
Pages: « 1 2   Go Down
Print
Author Topic: How do I repeat the cut of the same part?  (Read 809 times)
sawduststeve
Active Member
Offline Offline
View Profile
« Reply #10 on: March 15, 2011, 10:26:20 AM »
I am really impressed now that I learned about the enter key.  I used the multipass wizard to cut the Z depth in steps and then used the nesting wizard to repeat the part over the material size.
Steve.
derekbpcnc
Active Member
Offline Offline
View Profile
« Reply #11 on: March 15, 2011, 02:16:49 PM »
I've only been using Mach for about 3 or 4 years.....
where is the nesting wizard? Embarrassed Embarrassed Embarrassed Embarrassed
ATB
Derek Embarrassed
You can "chop it off" but can't "chop it on"
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #12 on: March 15, 2011, 02:21:24 PM »
 Smiley
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
derekbpcnc
Active Member
Offline Offline
View Profile
« Reply #13 on: March 15, 2011, 02:28:22 PM »
Jeez !
I've been down that list about a billion times !
Normally straight to the Write text wizard.
Well at least thats my "dumb question of the week" out of the way LOL
Smiley
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #14 on: March 15, 2011, 02:44:09 PM »
Cheesy
Me too ... and still finding something new there on occasion. Grin
Abe Lincoln
Toymanf
Active Member
Offline Offline
View Profile
« Reply #15 on: March 20, 2011, 11:18:40 PM »
You can also use G52 to offset the axis you want.
G52 X5Y5 creates an offset in the x and y of 5 inches(in inch mode).
You must remember to cancel any such offset with a G52 X0Y0Z0 or call out the new desired offset.
This is probably well known, but I was happy to find it a while back and it has come in handy.
Frank
Pages: « 1 2   Go Up
Print
Jump to:
