Hello Guest it is June 12, 2026, 03:22:46 AM
Author Topic: AutoZero Plate for Z Axis  (Read 70122 times)
Offline kolias
  •  1,165 1,165
Re: AutoZero Plate for Z Axis
« Reply #60 on: March 06, 2011, 01:21:44 PM »
My wiring problems came back LOL, had not a good luck this morning.......
First I think that is an easy one; I put the wiring on the Y & A axes as before and the Y limits (Home & +) works fine – when I trigger the lever the LED comes on on the diagnostic screen and I hear a bib but on the A axis the LED comes on but I hear no bib. Perhaps because A is slaved to Y ?
Now the big problem is the X & Z axes, cant get the limits to work. First I did the same canges as I did yesterday on the Y & A and it did not work ( I connected inside the control box the red from X to black from Z)
Then I connected the red from Z to black from X and again did not work. What puzzles me more is that on the diagnostic screen I see the following LED ON.
First I see no LED under the X axis no matter what and I find this strange
When I manually activate any limit on X or Z I see the following LED all together
Under Y axis M1++Limit, M3++Limit
Under Z axis M1--Limit, M3—Limit
Under A axis M1 Home, M3 Home
When I turn off the power to the control box I see on the diagnostic screen the following LED
X No LED
Y M1++Limit, M2++Limit, M3++Limit
Z M1—Limit, M3—Limit
A M1 Home, M2 Home, M3 Home, M4 Home
I know about your 2010 screen Gerry and I will investigate about the VB script when I finish my wiring problems
Nicolas
« Reply #61 on: March 06, 2011, 01:25:23 PM »
Are your Y, Z, and A all on the same pin?
Offline kolias
  •  1,165 1,165
« Reply #62 on: March 06, 2011, 01:58:27 PM »
No
A=Pin 10
Y=Pin 11
X & Z=Pin12
Zero Touch Plate=Pin 13
Nicolas
« Reply #63 on: March 06, 2011, 02:17:43 PM »
It sounds like you have some serious wiring issues then. Or, your pin assignments are wrong.
Offline kolias
  •  1,165 1,165
« Reply #64 on: March 06, 2011, 02:20:25 PM »
Pin assignments are correct, so I got to work on the wiring to find out what I did wrong
Nicolas
