Hello Guest it is June 11, 2026, 04:17:14 PM
Author Topic: gcode G00 Y -40  (Read 11135 times)
gcode G00 Y -40
« on: November 14, 2010, 03:42:05 PM »
hi, can anyone help please all my g code start with G00 Y -40  even when iam try to wrihe small name within 2 cm square ?   why gcode go too big G00 Y -40, thank you
Re: gcode G00 Y -40
« Reply #1 on: November 14, 2010, 04:20:14 PM »
What writes your code for you?
Re: gcode G00 Y -40
« Reply #2 on: November 14, 2010, 04:26:05 PM »
thanks for reply i typed letter  in artcam  and try to make small  name necklace   and transfer to gcode through artcam and put in mach3  i became very big G00 Y -40  .
Re: gcode G00 Y -40
« Reply #3 on: November 14, 2010, 04:41:35 PM »
Looks like your drawing in ArtCAM may be too big, either that or you need to do some scaling. Afraid I am not familiar with  ArtCAM so cant really advise :(
Re: gcode G00 Y -40
« Reply #4 on: November 15, 2010, 08:25:48 AM »
If the G00 Y-40 is the first move in the G-code, then it sounds like your part is set up in ArtCam 40 units on the Y axis from zero origin.  If that's the case, when you zero the DRO's in Mach and run the part, then the first move would be a rapid move to where the part is oriented in ArtCam.
Offline GaryB
  •  108 108
Re: gcode G00 Y -40
« Reply #5 on: November 15, 2010, 10:14:40 AM »
you are using the wrong post processor if that's the first line of code output.
Which post are you selecting in ArtCam
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
Re: gcode G00 Y -40
« Reply #6 on: November 15, 2010, 05:15:52 PM »
thanks for your answers  i got problem after i put the name into toolpath coz the letter abit small its me i dont know how to chose right tool i will learn but i need more information thanks
