February 13, 2012, 05:31:07 AM
Search:     Advanced search
+  Machsupport Forum
|-+  General CNC Chat
| |-+  Show"N"Tell ( Your Machines)
| | |-+  X machine-Like
Pages: « 1 2 3 »   Go Down
Print
Author Topic: X machine-Like  (Read 1909 times)
manmeran
Active Member
Offline Offline
View Profile
« Reply #10 on: August 27, 2010, 06:35:09 AM »
Amir,
That looks much more solid and rigid. Nice progress.
thx Dan
I think the changes implemented will be useful
Amir
**Even a clock that does not work is right twice a day**
manmeran
Active Member
Offline Offline
View Profile
« Reply #11 on: August 31, 2010, 08:26:13 AM »
update
Dan13
Active Member
Offline Offline
View Profile WWW
« Reply #12 on: August 31, 2010, 09:55:41 AM »
Nice visual effect on the last photo. How did you do this? Used a manual zoom lens? Or was it unintended?
manmeran
Active Member
Offline Offline
View Profile
« Reply #13 on: August 31, 2010, 11:58:27 AM »
Photoshop
Amir
zafarsalam
Active Member
Offline Offline
View Profile
« Reply #14 on: August 31, 2010, 09:58:38 PM »
Good going. What are the plans for the counter weights for the Z-axis.
Zafar
manmeran
Active Member
Offline Offline
View Profile
« Reply #15 on: September 01, 2010, 02:56:07 AM »
with Gas spring
Amir
manmeran
Active Member
Offline Offline
View Profile
« Reply #16 on: September 10, 2010, 03:24:21 PM »
i change design for Z axis.
I've decided that use DC motor (180V ,5A ,3300RPM ,1.2HP ) for spindle.
Amir
Sam
THIS SPACE FOR RENT.
Global Moderator
Offline Offline
View Profile WWW
« Reply #17 on: September 10, 2010, 09:23:05 PM »
Looking nice, Amir. I wish I had a surface grinder that large! Those ball screws look very familiar, may I ask where your getting them? Thanks for sharing your project with us.
"I sometimes think we consider the good fortune of the early bird and overlook the bad fortune of the early worm." FDR - 1922
manmeran
Active Member
Offline Offline
View Profile
« Reply #18 on: September 11, 2010, 02:01:34 AM »
thx Sam
I dont remember where I talk about the ball screw even in the picture  Grin
BUT re ballscrew:
All equipment used in this project is related to the chip Mounter machine.
ballscrew used in X and Y is 14mm and pitch 2mm , for Z is 16mm and pitch 10mm.
all LM Guides is IKO and ballscrews is THK.
Amir
« Last Edit: September 11, 2010, 02:07:30 AM by manmeran » Logged
manmeran
Active Member
Offline Offline
View Profile
« Reply #19 on: September 24, 2010, 07:15:04 AM »
After a long time ,Update
spindle build ER25 with 3 PFI ballbearing.
i use 2:1 pully between motor and spindle.about 6500RPM.
Amir
Pages: « 1 2 3 »   Go Up
Print
Jump to:
