Hello Guest it is June 12, 2026, 08:32:12 PM
Author Topic: video window won't work  (Read 34793 times)
Re: video window won't work
« Reply #20 on: September 10, 2011, 08:13:58 AM »
my programs use AVICap which supports streaming video capture in real-time and the MCI (Media Control Interface).
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline nava
  •  45 45
« Reply #21 on: September 10, 2011, 08:17:22 AM »
it seems to me that to make the camera window compatible  with many more cameras then using the Directshow would be a much better choice for mach3..would seem to be the simple choice at least.
Offline nava
  •  45 45
« Reply #22 on: September 10, 2011, 08:18:22 AM »
Sorry cant seem to find a solution other than the dirextshow:(
« Last Edit: September 10, 2011, 08:28:20 AM by nava »
« Reply #23 on: September 10, 2011, 08:36:14 AM »
In a German forum, someone had problems was an older processor (800MHz). When he turned on the camera the system got very slow.
To help him find the reason for that, I've wrote that plugin. Since then the plugin was growing and growing. The camera you are using is obviously an industrial type.
If you find a solution or a way I can help you (without adding DirectX) please let me know.
Klaus
Offline nava
  •  45 45
« Reply #24 on: September 10, 2011, 08:47:49 AM »
My information page lists the following drivers that my camera can use
ActiveX driver
DirectShow Driver
Twain Driver
And Im running wondows 7 32 bit.
What language are you programming this in? And on windows or Linux?
« Reply #25 on: September 10, 2011, 08:52:54 AM »
I'm programming in C++ without MFC on a windows platform.
Klaus
Offline nava
  •  45 45
« Reply #26 on: September 10, 2011, 09:15:28 AM »
Ok you dont need the whole of directx to use directshow, its included in the windows sdk,  There is a sample called amcap under samples/multimedia/directshow/capture which works with my camera.  It should be able to work without MFC?
adam
« Reply #27 on: September 10, 2011, 12:11:27 PM »
Hi Adam,
the programs are downloaded a few hundred times and obviously running well. I don't think I will implement directshow,
which would would need a complete redo of the camera - part, sorry.
Klaus
Offline nava
  •  45 45
« Reply #28 on: September 10, 2011, 12:48:12 PM »
Yeah no problem Klaus I don't really expect you to:)
