Hello Guest it is June 11, 2026, 10:54:50 PM
Author Topic: Feed & Speed Over Ride  (Read 28311 times)
« on: January 27, 2010, 08:30:21 AM »
Are there any how to's to set these up.
The manual is very clear how to add a switch, i would like step by step info on how to get the pots working.
Again very easy to connect the pot but then what ?
Phil
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Feed & Speed Over Ride
« Reply #1 on: January 27, 2010, 10:53:15 AM »
Have a look at this link, this how Hood made his pokeys pendant.
Graham
http://www.machsupport.com/forum/index.php/topic,11817.msg75561.html#msg75561
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #2 on: January 27, 2010, 12:10:31 PM »
You can also use seting PoPendant in Mach plugin. There are both overides already implemented.
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #3 on: January 27, 2010, 04:01:51 PM »
Graham thanks, i have tried the brains that Hood did but it is a little bit flaky for me.
Boris thanks, so can i use these settings although i am not using a pendant i just pretend i am.
Phil
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #4 on: January 27, 2010, 04:31:34 PM »
Yes you can be pretender  ;D
regards
Boris
« Reply #5 on: January 28, 2010, 12:25:12 AM »
Boris thanks,
I will pretend i know what i am doing today. ;D ;D ;D
Phil
« Reply #6 on: January 29, 2010, 02:30:24 AM »
Well it worked easier than i thought. But the speed was varying i ran the pokeys setup looked at the voltage on the Analogue inputs and could see the variance.
Then when i restarted they have now stopped working in Mach and no matter what i fiddle with i can't get them working again. But they are still working in the pokeys setup program.
What's gone wrong. ???
Phil
« Reply #7 on: February 06, 2010, 04:37:55 PM »
Phil,
 I too use the brains that hood wrote fro spindle/feed override and at first they were a little "flaky" as you put it.
It turns out that I had to rename them in order for them to work properly. Go into your mach folder, double click the brains folder, locate the brain in question and
right click on it and select "rename". Choose a new name...(remember not to use any spaces in the new name) and try it again.
Worked for me....hope it does for you too.
Marc
« Reply #8 on: February 07, 2010, 10:05:25 AM »
Marc i did get Hoods brain working but it was "over complicated, unlike mine"  ;D ;D ;D
Anyway i found a simpler brain that is more of a match to mine here http://www.machsupport.com/forum/index.php/topic,9163.10.html
It works great there is only a slight variation which i should be able to sort out with some capacitors
Phil
« Reply #9 on: February 08, 2010, 07:26:03 AM »
Phil
Not sure if you are using that on the lathe, if you are then check it doesnt affect threading, if that Brian has no reset to 100% it will vary about the 100% and may alter the threading.
