Hello Guest it is June 10, 2026, 07:41:18 PM
Author Topic: MachScreen releases  (Read 482834 times)
0 Members and 6 Guests are viewing this topic.
Re: MachScreen releases
« Reply #10 on: November 24, 2009, 03:32:54 PM »
Thanks Klaus. You are just too good to us.  :)
Offline KTM
  •  92 92
« Reply #11 on: December 09, 2009, 11:23:13 PM »
Thank you Klaus, this is the best screen designer yet :D
Regards
KTM
« Reply #12 on: December 16, 2009, 05:22:02 AM »
Hey,
version V1.34 is available. Changes:
new control element "Image button transp." added. This is actually an image button without an image file.
the set-file name is now also shown in the caption of the property dialog
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline Vogavt
  •  260 260
« Reply #13 on: December 23, 2009, 12:01:16 PM »
Does this work for Windows2000 Pro?
I'm getting an error message when starting up. Says it can find the "gdiplus.dll" file.  (The dynamic link library gdiplus.dll could not be found in the specified path.....)
« Reply #14 on: December 23, 2009, 12:16:37 PM »
Hey,
I think gdiplus is included in W2k SP4. Do you have SP4 installed?
Klaus
Offline Vogavt
  •  260 260
« Reply #15 on: December 24, 2009, 07:30:56 AM »
Yes, SP4 loaded.
Downloaded gdiplus.dll and placed in windows\system folder. Working great!
Originally got an error for pagefile.sys being too small, but it eventually loaded. Played around with it and it looks super!
Thanks for the effort!
Vogavt
« Last Edit: December 24, 2009, 07:41:57 AM by Vogavt »
« Reply #16 on: December 28, 2009, 04:40:31 AM »
Hello
Version 1.35 is available. Changes:
Tooltips to toolbar added
toolbar icons added in help-file
elements can be sized / moved with "Position" parameters left, right, top, bottom, width and height. When left, right, top or bottom parameter is changed, the width / height is calculated. To move / size the element, press "Position" button. When width or height is < 2 an error is thrown.
Klaus
« Reply #17 on: January 11, 2010, 07:26:01 AM »
Hello to all,
version V1.36 is available. Changes:
Edit problem in overview corrected.
Project (set-file and corresponding bitmap files) can now be im / exported.
the layer of 2 selected elements can now be swapped.
In "overlayed selection" mode you can now select multiple overlayed elements.
Klaus
« Reply #18 on: January 26, 2010, 12:26:25 PM »
Hello,
version 1.37 is available. Changes:
unnecessary inquiry in project export for source path from version 1.36c removed. French text updated.
Klaus
« Reply #19 on: January 31, 2010, 12:20:27 AM »
Hi Klaus,
1. I LOVE Machscreen.
2. Could you make either the web address in the about screen a hyper link or could you add a check for updates button some where. I don't always come to this forum to look for updates but today I did.
Mike
