February 13, 2012, 04:26:51 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach SDK plugin questions and answers.
| | |-+  Finished Plugins for Download
| | | |-+  Webcam plugin with low CPU consumption
Pages: « 1 2 3 4 5 6   Go Down
Print
Author Topic: Webcam plugin with low CPU consumption  (Read 7277 times)
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #50 on: July 04, 2010, 09:59:49 PM »
Klaus
I have been using your video plugin since you first released it here.
Have not updated for a while and have done so now.  V2.08.1
Very good to have the control separate to the main window.
However the "Remember Window Position" is not working for me anymore.
It remembers the width of the window but forgets the height.
Greg
Klaus1311
Active Member
Offline Offline
View Profile WWW
« Reply #51 on: July 05, 2010, 05:47:40 AM »
Hi Greg,
I will fix that.
Klaus
Klaus1311
Active Member
Offline Offline
View Profile WWW
« Reply #52 on: July 05, 2010, 12:24:06 PM »
Hi Greg,
this is problem is fixed in version V2.8.2 and can be downloaded from my site.
Klaus
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #53 on: July 06, 2010, 05:04:26 AM »
Thank you very much Klaus.
Greg
peu
Active Member
Offline Offline
View Profile
« Reply #54 on: August 09, 2010, 05:27:45 PM »
Klaus, Im testing your plugin under win 7 and Im only able to open the crosshair screen, no video feed. Mach default video works ok.
To be able to see the crosshair I need to start the mach default video plugin first, otherwise camera is not detected by your plugin with a "No Camera Found" error messagebox
Is there something I can test?
my Setup:
what version of Mach3 are using 3.042.029
what is your processor speed intel quad core i5
how much RAM do you have 4gb
what display adapter  nvidia 9500gt
and how much Video-RAM are you using 512mb
Windows 7 ultimate
Thanks!!
Pages: « 1 2 3 4 5 6   Go Up
Print
Jump to:
