Hello Guest it is June 11, 2026, 04:13:32 PM
Author Topic: Lightspeed thanks to mach3  (Read 34491 times)
Offline faby
  •  74 74
« on: July 29, 2006, 05:06:16 PM »
Look at these 2 videos, you can see may machine working...
http://www.fxmodel.it/sgros.mp4
http://www.fxmodel.it/lightspeed.mp4
It's working at 4500 mm/min but it can reach 7500mm/min in working mode and 10.000 mm/min in rapid
Thanks to mach3
Re: Lightspeed thanks to mach3
« Reply #1 on: August 20, 2006, 03:34:27 PM »
Did you put up a description of your machine on here?  If not, can you.
That is some fast machining!!
Offline faby
  •  74 74
« Reply #2 on: August 21, 2006, 09:11:38 AM »
Sure,
You can see a picture here: http://www.fxmodel.it/fresa.jpg
Working area 1260 x 600 x 230mm
3 x Sanyo step motor 4A 3.5 Nm
3 x Micro step driver (italian made) up to 7A and up to 4000 steps/r
Pre loaded ball screw 20x5mm (I don't know if the translation is right)
1Kw 3 phase spindle, ceramic bb
Working speed (with mach3) up to 8000 mm/min (other software) up to 3500 mm/min
Rapid speed (with mach3) 10000 mm/min (other software) 6500 mm/min
Measured precision +/- 0.015mm
Bye Faby
FxModel
ynneb
« Reply #3 on: August 22, 2006, 02:31:46 AM »
Faby, your videos are asking for quicktime to be installed. Quicktime is bloatware, takeover ware, and will not be on many of our computers, especially since it is also know to cause problems with Mach3.
Can I suggest you encode your videos so they can open in winamp or even windows media player ?
Thanks.
« Reply #4 on: August 22, 2006, 06:12:17 PM »
real player will play these videos, thats what I watched them with.
ynneb
« Reply #5 on: August 22, 2006, 08:10:11 PM »
:) Real Player comes a very close second to Quicktime.
I am amased that people forget to use the free movie editor that comes with XP, and then export the videos out as WMV  (Windows Media Video)
At least that way you can pretty much guarantee all windows users will be able to view it without needing a 3rd party bloatware.
Offline faby
  •  74 74
« Reply #6 on: August 23, 2006, 09:47:18 AM »
I'll convert it next week.
bye fab
mzungu
« Reply #7 on: August 30, 2006, 07:56:44 PM »
faby
Can you post some more pictures of your machine?  Is the machine your design or did you purchase the unit?  I'm in the process of designing my own and am interested in the belt (or maybe chain) drive you have for the x-axis; the single stepper driving the two ball screws on each side of the table.
Thanks!
mzungu
Offline faby
  •  74 74
« Reply #8 on: September 01, 2006, 07:33:28 AM »
Hi
The machine is a personal project.
I think that in my case, the belt for use 1 stepper for 2 ballscrew, is the batter way.
I found either belt and pulley in a store near here (I live in Italy).
I'll post new pics as soon as possible.
I convert the videos in WMV format so anyone can see it.
www.fxmodel.it/lightspeed.wmv
www.fxmodel.it/sgros.wmv
Offline Glenn
  •  129 129
« Reply #9 on: September 04, 2006, 05:15:59 PM »
Faby,
Thanks for converting, great to see your machine is so fast!
Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
