Hello Guest it is November 10, 2026, 08:35:01 PM
Author Topic: Lightspeed thanks to mach3  (Read 38243 times)
ynneb
Re: Lightspeed thanks to mach3
« Reply #10 on: September 04, 2006, 05:36:21 PM »
Great videos. Your machine moves very fast indeed.
Thanks for showing us.
« Reply #11 on: October 20, 2006, 10:30:58 AM »
Faby would it be possible for you to provide a more detailed compontent list. Are ball screws used everywhere, or are you using some belts?  Type of rail system and any other ifo that you could include??
Mike
Sure,
You can see a picture here: http://www.fxmodel.it/fresa.jpg
Working area 1260 x 600 x 230mm
3 x Sanyo step motor 4A 3.5 Nm
3 x Micro step driver (italian made) up to 7A and up to 4000 steps/r
Pre loaded ball screw 20x5mm (I don't know if the translation is right)
1Kw 3 phase spindle, ceramic bb
Working speed (with mach3) up to 8000 mm/min (other software) up to 3500 mm/min
Rapid speed (with mach3) 10000 mm/min (other software) 6500 mm/min
Measured precision +/- 0.015mm
Bye Faby
FxModel
